When utilizing a Painless wiring harness, the alternator excitor wire needs to be wired into the regulator's white w/red stripe wire. I then spliced a wire directly into the hazard switch for power per the original wiring diagram for my 73. If you do not plug the excitor wire in here, the battery will not charge...I learned the hard way, luckily I wasn't far from home!
