Fuse for Radio in 80?
New Mexico/Colorado
Help! I am installing aftermarket 2X din receiver, but about 5 seconds after intitial power-up power went off...checked fuse on unit, its fine. I did not splice into factory harness, i used aftermarket harness, connected correctly (done this a few times before...)color by color. Wondering if new unit is pulling more power than stock unit? To confirm i didn't zap my existing unit, i plugged stock unit back in and it didn't power up either.
Where is the fuse for the Radio in 80 or is there one? :confused: Thanks!
It's either under the little pannel under the dash or under the big cover under the bonnet. My after market stero does not blow the fuses.
Paul
I read somewhere on Mud that there's a lot of things hooked up to the same power wire that provides power to the radio. based on that, I decided to run my own 12GA power wire and ground. It was a pretty easy wire run, plus no problems on my end. :)
Well, i had two seperate fuses that popped...which concerns me. One under the hood (dome) and the Cig under the dash. Power comes on now, but i know there is a short somewhere. Power to my unit comes on, but sound through speakers is very distorted, heat sink on unit gets hot very fast. I know it has something to do with the harness hook ups, but i don't know where to look since the colors all match up. Wonder if the factory amp has anything to do with this? I might just have to run new wires to all the speaks :frown: in the cruiser? This unit has all the bells/whistles on it, it may not be compatible with aftermarket harness, who knows...
Make sure you don't connect the power antenna lead (blue wire?) from the radio to the wiring harness. I accidentally did this and it blew the 10A fuse on the radio. Not sure they are all the same, but I have the pioneer double din.
