Fuse Blocks
Colorado Mountains
Ideas/suggestions for alternatives too the mid 60's fuse blocks?
Cant seem to find an NOS one.
Pics?
x 2
Blue Sea makes a 6 circuit fuse block Part #5035 that will work. You will need to order the jumper kit to allow you to jumper the input side to match the OEM fuse block. (three switched and three always hot) It will even bolt up to the same holes though it will sit a bit crooked. I made up a small backing plate to bolt it up properly.
Uses ATC fuses and comes with a cover. http://shop.pkys.com/product.asp?itemid=1621&gclid=CMWA-Yj5wMQCFQeNaQodDEMA8Q
For my LV resurrection, I bought an aftermarket fuse block from Mr. Carlyn Dinkler (cdinkler at bellsouth dot net) a retired electrical engineeer who lives in a small town not from from mine. Per his email, he specializes in parts for the 1965-70 Corona RT43/52, the 1969-72 Corona Mark II RT6#/7#, and the 1970-73 Corona RT8#/9#. Below is from an email I received from him last fall:
I have Toyota and aftermarket, fuse blocks and fuse kit. S=stock
(329) 1 82610-30022/82600-30022 BLOCK ASSY, FUSE SIX 6501 to 6809 or 6810, RT43/52, RK41 & other DISC BY TOYOTA
STOCK FUSE PANEL LHD FUSES: FROM THE FRONT: LIGHTS 20A, HORN 20A, SPARE 20A, METERS 5A, WIPER 15A, TURN SIGNAL 15A
NEW TOYOTA WITH FUSES 57.68S
REPRO. W/O FUSES (Cover stamping slightly different from original) made in China 17.50S
(329B) 1 82600-FUSEK-TOY01 FUSE KIT, TOYOTA FIVE 20A, TWO 5A, THREE 15A 12.00S
-or-
(329C) 1 82600-FUSEK-NTA FUSE KIT, NEW AFTERMARKET FIVE 20A, TWO 5A, THREE 15A 5.00S
Please give your shipping address (I normally use USPS or FedEx ground home delivery). Simple orders (a few stocked items that are easy to pack), I try to do quickly. Complex orders (orders that include items stocked at the farm (large storage) or that have to be refurbished before shipping) may take weeks to months.
Payment: For orders greater than $100 I prefer a check, MO or Chase QuickPay & I will give a 5% discount. For orders up to $100 you may use paypal without the discount, or use a check, MO or Chase QuickPay to get the discount.​
Local Toyota just confirmed early fuse blocks (5 or 6 fuse flavors) are no longer available
