Howdy-
Past few days I have had a problem getting a smooth idle right after restarting the 2f if it is already hot.
I used the choke to smooth it out and after I ran it a block or so, everything smoothed right back out (and the choke was not engaged anymore either). It will run smooth until I park it again, and it only idles rough for the first block or so. When rough I am erratic around 550 rpm, when smooth I am just over 800 rpm.
Only thing that is different is I moved to higher elevation in Colorado, about 5K ft or so. My carb may need adjustment, but it ran great back in Iowa before my move (Jim C. carb)
Any ideas... I was thinking a stuck PCV valve? What should I check?
Thanks in advance
REZARF <><
Thanks in advance
REZARF <><
