- Location
- United States
'84 FJ60 Land Cruiser Front Axle:
- Trail Gear 6 stud knuckles
- Trail Gear 6 stud arms (modified for double shear and 3/4" bolts)
- Trail Gear Magnum Studs
- Trail Gear Trunion Eliminator
- Trail Gear thick ball wiper and rock rings
- Trail Gear Drive Flanges (missing two dowel pins)
- Trail Gear backing plate eliminator
- Longfield 4340 30 splines shafts
- ARP hub studs
- Chevy 12 Bolt mini spool
- 3.73 gears
- Vented rotors
- All wheel bearings in good shape, replaced end of last summer.
- Loaded calipers with plenty of pad material left, includes adapter to AN 3
- Old Man Emu FJ40 2.5" leaf springs (drilled center pin for 1/2" socket head cap screw)
- Housing: shaved, knuckles cut and turned, set up for double ended ram steering, solid steering stops, knuckle ball gusset, relocated fill plug
$1,900 for the whole package.
I'm in Tucson AZ for local pickup. For additional $$$ I will consider shipping or meeting someone halfway if the distance is reasonable. PM me and we can discuss.
John
- ARP hub studs
- 3.73 gears
- Vented rotors
John
