putting together a F/F rear and going reart disks also. wondering if the disk brake adapter brackets are the same or are they different then the standard brackets for the standard axles. anyone have experience with this? appreciate the input.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Do the 80 rear discs not fit the 60 FF housing?
Just had a quick look at the FAQ and did not see any relavent listings.
The thread 2tall supplied is for a 40/45: already made that mistake & bought mini-truck knuckles & had them cut down & powdercoated for adapters only to find out they wouldn't fit the 60FF.
I'm in the middle of doing what you're contemplating & had TSM make me prototypes of brackets to use 60/62 calipers on the rear (already have their proto tcase parking brake). FFs are different than SFs. My big hangup was making dust shields out of the drum backing plates & 60 front dust shields.
If you want to keep rear park brakes your only readily-available option is the Eldorado single-piston, floating-frame caliper, which TSM sells new. But there have been endless complaints about that setup not self-adjusting, to the point where you don't have an effective park brake.
My TSM tcase disc park brake is easily 3-4 times more effective than stock: https://forum.ih8mud.com/60-series-wagons/246398-tsm-split-tcase-disc-brake-prototype-2-a.html
Again, I am a shameless, unpaid shill for TSM: Cliff & Skip are the best, bar none.
Lack of 15" wheel clearance potential rears up and smacks me!80 rear disks have monstrous rotor hats which double as drum brakes on the inside, which is the 80's emergency brake. I am pretty sure you could only use them with the 80 hubs, which supposedly have the same bearings as the 60. That said, I don't think you can just slap 80 rotors on a 60 hub, but I don't know for sure
Other than that I don't see a problem. The rotor hat style p-brakes have been the better overall design IME.
