- Thread starter
- #141
I’m stayin away from those from here on out!!!Or by any puny Broncos...![]()
I’d use one of the supplied holes and shorten the sway bar arm!“Add in a little more front sway bar”? By what means?
Way to go “princess”!I’d use one of the supplied holes and shorten the sway bar arm!
Is that for hydro assist?I did something today. I mostly mounted the oil cooler. I can’t tell if the crossmembers crooked if the body is crooked, or if I just mounted it crooked. I also couldn’t get one of the to nuts to seat so it’s mounted with 3. Apart of me cares a lot, but appart of me knows that it’ll get hidden behind the bumper and I’ll never think about it again
Siiiii, I’m doing this guy and I’m cutting and extending the stock reservoir for more fluid volumeIs that for hydro assist?
Better reservoir solutions are at your finger tips.Siiiii, I’m doing this guy and I’m cutting and extending the stock reservoir for more fluid volume
But I’m cheeeaaaapppp and the psc one is so wildly overpricedBetter reservoir solutions are at your finger tips.
What’s not over priced especially with Land Cruisers? With the PSC you get a better and easily replaced filter and a second return port (on the correct p/n) for when you install a hydro booster. Plus, it’s a handsome unit with a lid that actually seals.But I’m cheeeaaaapppp and the psc one is so wildly overpriced
I went with the Chase Bays reservoir with the S-14 mount and modified it a bit. Way cheaper than the PSC and has been greatBut I’m cheeeaaaapppp and the psc one is so wildly overpriced
I’ve been hearing good stuff about radial dynamics. If I was going to fork out some serious dough I’d probably lean that way!What’s not over priced especially with Land Cruisers? With the PSC you get a better and easily replaced filter and a second return port (on the correct p/n) for when you install a hydro booster. Plus, it’s a handsome unit with a lid that actually seals.
I went to the site. Talk about glorification in the name of over pricing a fluid reservoir. Dang!I’ve been hearing good stuff about radial dynamics. If I was going to fork out some serious dough I’d probably lean that way!
Until then…. I’m being cheap![]()
The tech on them is pretty cool!I went to the site. Talk about glorification in the name of over pricing a fluid reservoir. Dang!
Others here on mud have done the same with great resultsI’m going to be chopping the lip off and welding on a 3.5” piece of exhaust pipe to make it deeper. I saw the trick in a pirate post from like 14 year ago or something. It’s fun/ easy/ cheapView attachment 3621776
Yap, hopefully with an 80 that works!Others here on mud have done the same with great resultscarry on.
You still heading to Sand Hollow in a few weeks?
