fuel tank question...to many pipes (1 Viewer)
Kansas!
putting in a new fuel tank....tank is from a 70 fj40...mine is a 1968...i have the filler pipe and another small pipe (vent?) to hook up to my cruiser...this tank has 3 additional small pipes..that apparently went to some fuel gadget on the later models...can they be plugged?...if so what would be the best method?..thanks in advance fellas for the help
osagecruiser
High Desert, SoCal
I think the extra pipes are for vapor recovery (smog). I hooked mine together with a T. I wanted to ask you how much paint you used to paint the FJ? I am getting ready to do mine.
Thanks
Brad
High Desert, SoCal
I just used a brass one that I had and hooked it all together with small pieces of fuel line and clamps. I would think a solvent resistent plastic one would also work. If you could find some caps and clamp them on, that would be even better.
high desert, ca
I did a similar thing recently, but it was on a 55. Much different tanks. At first I capped all the extra lines, but then the insufficient venting made it difficult to fill up the gas tank. Gas pumps would shut off unless I pumped very slowly. So I uncapped it all, added a fuel seperator and a charcoal canister, now it works correctly. Just food for thought.
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
