bloc
I have an LS in my rig and I haven't worked out every little detail yet.. the fuel tank evap system being one. For the time being, the line from the tank normally to the charcoal canister is vented to atmosphere. I'm not proud of this, and it will be fixed when I install the GM tank pressure sensor.
I've put a lot of miles on like this, and usually the rig stinks of gasoline and there is no tank pressure. Clearly the line is clear.
Sometimes though, no smell, and a large whoosh when I open the gas cap.
When I did the body swap I noticed that the fuel tank vent isn't just a line off the top. There is a somewhat complicated valve that seems to be to stop fuel tank flow in the event of a rollover. It also seemed to have some low density plastic in it.. like a float.. to stop off the vent if fuel gets that high.
I wonder if this valve isn't working correctly all the time (closing too early, then tank pressure keeping it closed) and trapping evap pressure in the tank in rigs with otherwise healthy charcoal canisters.
Thoughts?
Thoughts?
