FUEL not makein it from the tank
Discussion in '40- & 55-Series Tech' started by kling-on, Mar 28, 2004.
  1. kling-on
    kling-on Kool Arrow
    5,497
    Media:
    12
    Albums:
    1
    116
    Apr 26, 2003
    Pimpin part in SanAntonio TX
    OK so ya'll that made it to the the round up know I have a fuel problem .... I have replace the fuel pump, filter, pulled the to off of the carb (thanks Edwin) and I pulled the inspection cover yesterday removed the float and you can see the pick up and there isnt anything there. Something is blocking the fuel from the rear cause i put air on the line and you can see it build up presure and then drops and gas flows back .... is there something I'm missing between the fuel filer under the hood and the tank ...:mad: FAWK I'm so mad I dont know what it is.
    Thanks in advance for any help .... I dont want to pull EVERY line and ck them if theres something I dont know :'(
  2. kling-on
    kling-on Kool Arrow
    5,497
    Media:
    12
    Albums:
    1
    116
    Apr 26, 2003
    Oh ya the tank was replaced under the recall and i got about 200 miles on it before this all started
  3. Romer
    Romer fatherofdaughterofromer Moderator
    10,850
    2,145
    Sep 14, 2003
    Centennial, Colorado
    Don't know if you have a 40 or not, did you take the passenger seat off and check the fuel sending unit to make sure it's not blocked? If you take the hose of the Fuel filter, is there gas inside the filter or the hoses leading upto it. You might also try blowing on the line at the input side of the filter and having someone watch the tank and see if the air is getting through. Could be that the new tank had some crap in it that worked its way in to the line and clogged the system.
  4. kling-on
    kling-on Kool Arrow
    5,497
    Media:
    12
    Albums:
    1
    116
    Apr 26, 2003
    [quote author=Romer link=board=1;threadid=13834;start=msg128293#msg128293 date=1080497637]
    [/quote]
    no its a 60 I removed the sender and looked into the tank the pick up is under it to the right and i dont see anythinf in there ... I wosh it was a 40 I know the fuel system on them better
  5. jwest
    jwest
    688
    1
    Mar 12, 2004
    Frozen sender or blocked suction line?
  6. 3_puppies
    3_puppies SILVER Star
    10,340
    1,080
    Dec 2, 2002
    Helena MT
    Are you sure there are no other filters in line? from a PO. happened to someone else here a year ago.
