Fuel Line(s) question
Discussion in '40- & 55-Series Tech' started by RickD, Mar 20, 2004.
  1. RickD
    RickD
    46
    Apr 15, 2003
    Two fuel lines come out of the top of the gas tank on my '82 FJ40. They connect to two lines on the frame that run to the engine. One goes to the fuel filter and on to the fuel pump. The other connects directly to the fuel pump.
    Does it matter which one connects to which ? Can't find anything in the manual that tells.
    Thanks
  2. Pin_Head
    Pin_Head
    14,458
    2,029
    Feb 6, 2002
    OC, CA
    [quote author=RickD link=board=1;threadid=13442;start=msg124369#msg124369 date=1079812846]
    [/quote]
    Absolutely. One is the fuel line and the other is the vapor return. It is easy to tell which is which: Only one will produce fuel when you pull a vacuum on it.
  3. Romer
    Romer fatherofdaughterofromer Moderator
    10,705
    1,752
    Sep 14, 2003
    Centennial, Colorado
    On my 77 the fuel filter is closer to the tank almost under the battery. The Fuel Pup is in front of the oil filter, The libe to the filter would be shorter if you have the same setup
  4. HI^C
    HI^C
    1,234
    2
    May 22, 2003
    blow down them, the one that makes bubble sound in the tank is the fuel supply, other will just blow air. Easy stuff, LOL
  5. Bucket
    Bucket
    29
    Dec 23, 2003
    Cookeville, TN
