1999 Land Cruiser.
I searched and searched. Found plenty of threads about faulty sending units and replacing them but nothing about the persisting issue.
A couple of weeks ago I ran out of gas on the highway, although my fuel gauge read that I still had 1/4 tank. I took it to a shop here in Houston that specializes in Toyota 4X4's. They assumed that the issue was the sending unit, pulled and tested it, which confirmed that the reading was off. After replacing it, the gauge now reads just over 1/2 tank, even when completely full. They examined the wiring up to the cluster and told me that everything looks fine. The shop owner suspects that the problem is in the instrument cluster and recommended that I find someone to rebuild it or find a used cluster from a part out and swap it in.
I have a bad taste in my mouth from the whole experience, however, my main focus is getting the issue resolved.
Has anyone experienced this and have some insight or direction for me?
Also, if I swap clusters, is there a way to change the odo reading so that it is accurate to my vehicle?
Thanks!
Thanks!
