Fuel Filter Suggestions
BreckenridgeCruiser
I break things.
Oceanside, CA
Website
teqtach.com
I'll catalog that source, but I need i in about a week and that may take a while to come from the UK. Any other suggestions?
Thanks!
You should be able to use anything off a diesel of similar cc. The thing to look for is cheap ,easily replaceable filters. I would get a Delphi 296 for starters and maybe add a factory pre filter later.
You must have some kind of diesel specialist shop that has a range of filtration options where you are?
I bought one of these for my Hilux from this same seller. The one I bought has a steel sedimenter bowl instead of the glass one. I mounted it on the frame rail near the tank. The heater works well with a rotary injection pump like the 1HZ because it constantly circulates fuel back to the tank. I built a thermostat circuit for it so the heater shuts down when the fuel entering the pump is >78F.
