First, thank you for helping and sharing your thoughts. here is what i have going on with my 77fj40:
- Car starts and idles fine and drives fine under first and second gear and even into third because for the most part RPM's are up and its at or close to full throttle. Once i am not having to be at full throttle in 3rd and 4th gear its missing or seeming to not get enough gas. After driving it for about 15 mins on the road it will even cut out at stop lights. Carb was rebuilt about 4 years ago and its not driven more than about 200 miles a month so maybe the lack of driving has caused clogs or issues with the carb or debris in it?
- I have checked vaccum and lines and all seems good
- I have pulled air cleaner lid off and let it run without and choked it out with my hand over carb so i can tell vaccum is strong
- I used to be able to go about 60-70 with ease and now i have to push the pedal thru the floor to get it up to 60.
- I pull the air filter out today to clean it and it smells like gasoline and the side closest to the carb actually appears to have gas on it.
- I have an exhaust leak i am sure about but i doubt this is causing this issue. I am going to have this fixed next week.
- Fuel filter is Toyota and brand new
- I have a new fuel pump i could install but since i am getting gas i am thinking that is not the issue.
