currently running a basic 15 gallon RCI aluminum sump setup, ahead of the rear axle and sitting in the bed of the FJ40....sumps face the rear....
looking to install a rear seat and the cell is VERY in the way....
plan is to install a RCI 2171A (30" wide, 17" tall, 7" front to back) with 17 gallons capacity and a pair of Walbro MP-13 pickups with a Y-fitting to connect them...
RCI
Auto Performance Engineering - Walbro fuel pick-ups
push the system to the back of the tub and leave plenty of room for a rear seat and some leg room...then modify the cage to protect the passenger (easy stuff) Rear seat is a 36" Corbeau bench
thots or comments? ordering parts in the next few days...'should' be a simple project....'should'
(hardest part is lowering the rear shock crossover....believe a cheap cut-sleeve will work for that tho
RCI
