Fual guage is now INOP after removing wires from sender.?
Discussion in '40- & 55-Series Tech' started by AATLAS1X, Aug 27, 2006.
  1. AATLAS1X
    AATLAS1X
    7,263
    15
    Jan 24, 2006
    97707
    Fuel guage is now INOP after removing wires from sender.?
    I was doing the big wash in my 40 today and after putting back the cover to tha gas tank I drove it into the garage and now the fuel guage is INOP......I unscrewed the ground and pull the wire from the sending unit. did I ground it by mistake and blow something??
    I checked all fuses and all are good. I have a pulse at the sending unit with a test light.
    What did I do or miss???
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,384
    Media:
    17
    Albums:
    1
    758
    Oct 1, 2003
    MN
    Check the connectors at the sender.... it is likely a ground issue.
  3. AATLAS1X
    AATLAS1X
    7,263
    15
    Jan 24, 2006
    97707
    I did, and I moved the ground to another screw.
  4. AATLAS1X
    AATLAS1X
    7,263
    15
    Jan 24, 2006
    97707
    How is the tank grounded? Or is it?
  5. honk
    honk
    3,413
    Media:
    10
    368
    Nov 14, 2004
    PNW
    Ground the sender using a jumper cable from the sender bod to a known good ground. If the gauge does not swing with your new temporry ground then trace the OEM ground wire to be sure you didn't disconnect, break, or soak it.
    As far as the gauge work it doesn't matter about the tank being grounded, and it normally isn't. If it was there'd be no reason for a seperate ground for the sender.
    ed:sp
  6. Doug_S
    Doug_S
    880
    Jul 19, 2004
    Olympia, WA
    Use the factory service manual's way of testing the gauage or you might blow it entirely like I did on my oil pressure gauge.
  7. camcruiser13
    camcruiser13
    6,978
    Media:
    3
    Albums:
    1
    28
    Jun 22, 2004
    sittin on the couch in UT
    did you connect the wires back up?
  8. AATLAS1X
    AATLAS1X
    7,263
    15
    Jan 24, 2006
    97707
    Did you see picture?:D
  9. fjwagon
    fjwagon
    1,838
    33
    Dec 7, 2004
    I take it......the fuel gauge is marking empty.....?
  10. AATLAS1X
    AATLAS1X
    7,263
    15
    Jan 24, 2006
    97707
    Yes it is reading empty.................................
  11. cruiser88
    cruiser88 SILVER Star
    11,879
    Media:
    3
    Albums:
    1
    287
    Feb 21, 2006
    Winston Oregon
    i had the same problem like it was spoken above it was a ground issue.i redid the ground and made a fusible link because somewhere along the way i blow my s***.just a liitle extra protection:eek:
  12. AATLAS1X
    AATLAS1X
    7,263
    15
    Jan 24, 2006
    97707
    that went a weak ago...........I have 20 feet on it in the past week and never had these issues with a 40....
  13. AATLAS1X
    AATLAS1X
    7,263
    15
    Jan 24, 2006
    97707
    what do you mean soak it?? I scrubbed the whole inside with hot soapy water from top to bottom..............
  14. AATLAS1X
    AATLAS1X
    7,263
    15
    Jan 24, 2006
    97707
    Real time in the garage 12 midnight
    Ok, I took a test light to the clip on wire to the sender, it pulses and the guage deflects slowly 5-7 seconds. I ran a ground hard line to every place I could find from the ground on the sensor.
    I crawl under and find the plug, check it and all looks good. i move over to the ground at the frame (see pic) and I find a SOLID BLACK wire that looks OE, But I have never seen a sold black wire that was??? anyway, the yellow tape is still around harness and black wire comes out (see pic) i hit the black wire with a test light and I get a click......I hook up a extension and locate the click. Its coming from the black emission box (see pic) WTF??
    Still no gas guage, still no oil pressure guage and now this. all worked a week ago....
  15. AATLAS1X
    AATLAS1X
    7,263
    15
    Jan 24, 2006
    97707
    hummm
  16. AATLAS1X
    AATLAS1X
    7,263
    15
    Jan 24, 2006
    97707
    Black wire? anyone?
  17. baldboy
    baldboy
    561
    30
    Jun 16, 2006
    Tulsa, OK
    I had the exact same thing happen about a month ago. Same emission box clicking, fuel guage died for no reason, same everything.....
    Fuses looked good, changed grounds, still no go..... (oh btw, the horn went out at the exact same time so I figured ground is bad somewhere...nope)
    I know this might sound elementary but it turned out to be a fuse that looked new and was bad.
    As for the black wire, I would ignore it if you never touched it before and the fuel guage worked before.
    Long story long, try changing all of the related fuses (fuse).
    I know I know, it sounds stupid but it worked for me.
    Good luck and sorry I didn't have a more enlightened solution.
  18. stumpy
    stumpy
    414
    2
    Jun 15, 2005
    The Intarwebs
    have you run a ground wire directly to the battery? sometimes that helps me when i am fiddling with a ground problem. rub the ground wire ring that screws into the sender with a piece of sandpaper. that usually solves it for me.
    HTH
  19. AATLAS1X
    AATLAS1X
    7,263
    15
    Jan 24, 2006
    97707
    Ran a ground wire from sender to --- side of battery.,............Nothing.
    that black wire in the pics, well my 79 frame has is connect to the white and black wire at the ground on the frame.....????????????????
  20. mooker82
    mooker82
    1,696
    23
    Nov 3, 2004
    Charleston, SC
    Not sure if theres one on a cruiser but on my early bronco i had the same problem There is a small voltage resistor that cuts the current from 12 volts to 6 or something that is located on the back of the gauge panel.
