FSM says...timing
Albemarle NC
Fsm says " Using timing light slowly...aligned with the 7º mark. Ignition Timing: 7º BTDC @ Idle 13. FURTHER CHECK IGNITION TIMING Ignition Timing: Approx. 12º BTDC @ Idle
So why does the timing advance after you pull the connector from TE1 and E1? If the timing is already at 12º BTDC then should I still advance it?
