Trade fs/ft Exo Suzuki Samurai
Im looking to trade/sell my suzuki samurai im looking for a fj60/fj40 im located in michigan.
1988.5 exo sami , it has 147k miles on body ,NOT ONE LEAK,all fluids are brand new, 45k on motor snorkel running into cab, flex fan delete, powersteering,, exo cage with front stinger w/ a roller to get up rocks or a tree and rock sliders built in. 5 point rci racing harnesses driver and passanger, oil pressure ,coolant temp and battery voltage gauges 15 gallon rci fuel cell. push button start(clicky starter fix), lazy man cruise control, cb radio, power inverter, 2 12v outlets, first aid kit&fire extinguisher in the back with lights wired in so you can see what your doing at night ,fan for driver since theres no a/c. diamond plate door panels, All the gagues work execpt fuel gauge it can work i just never hooked it up when i did the fuel cell. as far as rust goes fame is 100% clean, body has a small hole in the rear "bed" maybe a golf sized whole, ive covered it, and then the fuel cell went over it. the rockers have rust not terrible i the fenders are in good shape execpt for a little quater sized hole on one rear one. inner fenders/battery tray/ rear wheel wells inside the truck all rust free. floor behind passanger seat theres some rust, nothings major atall, i drive it right now in the winter no cold air gets in, its pretty dang warm.
Petroworks clutch,trailtough unbreable trans mount, trans vented to cab
4.91 tcase gears w/ hd tcase mounts with billet mounts and vent routed to cab
SPOA w/ missing f&r links Rear springs are custom, Front has RUF FLEXS GREAT
Stainless Brake lines, Parking break works,breaks work great.
Street tires for the winter
Spool in rear end, rear also has pumpkin and vent routed to cab
Detroit in front also has pumpkin and axle truss up front,set of TT chromoly axles yet to go in.also vented OTT stering stage one
Driveshaft spacers (installed) and a full set of driveshafts for spares in perfect condition
Full power cutoff in cab incase of roll
lockable storage in rear, when i did the diamond plate on the tailgate i disconnected the outside handle so you have a pocket screwdriver to open it once the top is off(keeps people out)
New Best Top
New water pump ,thermostat,timing belt,timing belt tensioner.
Trucks located in livonia michigan, i can deliver up to 200 miles one way
PRICE IS 3,700 OBO which is a great deal for a turnkey crawler that u can drive on the road everyday with no worries.
Ill get them up here shortly!
The yellow strap is just to hold down my spare when i had one. ENJOY!
TDi
Looks like all it needs is a diesel;) Bump for the target of the next build.
if it had a diesel i wouldnt be selling it! with 31"s and the tcase gears though it has enough power for what i do.
Its 100% stock as far as the motor goes all the emission are there. so it might...... but i doubt it!
Forgot it has neon seats, got rid of the crappy stock ones
TDi
There are pretty slick adapter kits to drop in a TDi. Good luck with the sale.
Yea acme makes one, If i do a diesel conversion itll be to my yota not the sami. SOMEONE BUY ME!
comeon!!!!! MAKE OFFER
no problem BUMP IT Up
bump it up, need it sold guys, have a set of arb lockers and gears calling my name.
Sold sold sold
