2MinutesTurkish
it was two minutes, five minutes ago...
Highly doubt both bulbs went at the same time. I have no front turn signals. All other lights front and rear work. I've checked all fuses and they are good to go.
I am in the middle of doing an ARB bumper install and converting the side lens housing to put the blinkers in there as opposed to running the ARB in the bumper (no different wiring, just modifying the plastic side marker housing to fit the turn signal)
Currently, everything is wired up correctly. Side marker lights are still connected, just hanging for now.
When I hit the turn signal switch on the steering column, I get the fast flash for both right and left, but no front turn signals (only rear). When I hit the hazard switch, the rears only blink at normal speed.
Clearly I've done something as it was working even after I disconnected the fog lights and blinkers from the stock bumper. Any quick ideas or tips before I start troubleshooting. Multimeter is at the office and parts stores are closed. Wouldn't mind saving a trip to work and some cash before I just start heaving money and time at the problem.
