I probably don't. I am trying to describe the bar that runs perpendicularly under the front sway bar near the front mountsA pic might help.
Not sure you know where your panhard bar is![]()
I have edited this post with what I think is correct terminology. Sorry about thatA pic might help.
Is that was meant though? 7 hours and no suggestions? Mud has gotten slack! Or have no clarity on what's being referred toHaha we all know what he meant.
Radius Arm
Control Arm
Leading Arm
Whatever you want to call it, you can use a drop kit to lower the sway bar to stop making contact.
But @Jdub94 when you ask these kinds of questions in the future tell us about your truck, what year, what mods, what lift, how is it loaded, etc.
You're right maybe I am wrong, but the only thing that makes any sense is that what he actually means is tie-rod to radius arm, but I could be wrong!Is that was meant though? 7 hours and no suggestions? Mud has gotten slack! Or have no clarity on what's being referred to
Or is he referring to tie rod? Clashing with radius arm?
Or drive shaft clashing with sway bar?
Sway bar shouldn't clash with radius arms.
With a pic, doesn't matter if someone doesn't know what to call bits
this is what I mean
No, my radius arms are not making any contact. It is my sway bar that is making contact. I am on 37s. Not sure what the lift height is from the PO. I think 6"That would be your steering linkage (tie rod / drag link) hitting the control arms ( radius arm / control arm).
The only thing that would cause that would be a lift and caster correction.
Without knowing your suspension specs, ie type of lift and method of caster correction, it will be hard for us to help you.
But you might consider something like a radius arm drop bracket from @eimkeith or I also believe Ironman makes one. (Eimkeiths product is better)
Post some pics and suspension details for better help.
In the picture you posted, I clearly see contact between the right radius arm and the tie rod. There are contact marks on the tie rod.
You're saying that the front sway bar is touching the tie rod?
Need better pictures of what's going on. Get under the truck and shoot from the center to the front so we can see everything clearly.
Well that's just silly.He never posted a picture (not sure why not?).
He took someone else's picture to draw on.
Fellas I have a 3 week old newborn and already back to work full time. I don't exactly have a ton of time to go snap some pics. Since someone else showed the belly of theirs, I opted to do a quick edit to circle exactly the spot I am talking about. Please refer to the big red circles as to what I am trying to describe.Well that's just silly.
Yessir right away sirFellas I have a 3 week old newborn and already back to work full time. I don't exactly have a ton of time to go snap some pics. Since someone else showed the belly of theirs, I opted to do a quick edit to circle exactly the spot I am talking about. Please refer to the big red circles as to what I am trying to describe.
Just trying to ask around to see if anyone else has similar experiences and knows a fix so I at least would know what to get into or what direction to start moving.Yessir right away sir
Candor aside, I'd just ignore it since I doubt it's rubbing bad enough to matter, and if you don't have time to get pics, you're not gonna fix it
One of the great things about newborns is they stay where you put them, and they can't fall off the floor. They're soft and flexible, washable, and very resilient. BTDT. Twice.Fellas I have a 3 week old newborn and already back to work full time. I don't exactly have a ton of time to go snap some pics. Since someone else showed the belly of theirs, I opted to do a quick edit to circle exactly the spot I am talking about. Please refer to the big red circles as to what I am trying to describe.
They also love red bullOne of the great things about newborns is they stay where you put them, and they can't fall off the floor. They're soft and flexible, washable, and very resilient. BTDT. Twice.
