I checked my suspension yesterday to make sure all is well before I wreck it at Katemcy. I found one problem that I can't explain. There is a very long bolt with several bushings right behind the two front wheels toward the back of the knuckles. These connect one long bar that goes from each side of the truck just in front of the front diff. Is this the front sway bar? On both sides I was not able to tighten the nuts completely down on the bolts. They were a little loose and I could jiggle the bar back and forth a bit. Does this need to be fixed? What about buying new bushings to solve the problem? Or is it a problem?
Benji
Benji
