Front Sway Bar Bolt Size?
Minneapolis, MN
Anyone know the size of the front sway bar link bolt (part# 90119-10765)?
I ordered an oem bolt online but would like to throw a bolt in there for the next few days until the oem part arrives.
Thanks friends,
Ben
If you don't have the old bolt to match-up at hardware, perhaps you can pull other side. ACE has good selection, even better is at A&A (ACE) on SO Broadway.
It's an M10 1.25 pitch. You want about 30mm of unthreaded and a total length of 45mm. I went with a 55mm bolt since it had a 30mm unthreaded area.
thanks so much for posting this! I had to cut off my old bolt before realizing the nut was welded onto the mount. So to get the stub out, i had to drill it out, but now my threads are trashed, so I'm a little stuck whether to try and tap it, or just find a locknut to fit on and buy a slightly longer bolt.
