front sway bar attachments
Flagstaff, Arizona 7,000 feet
Howdy
the bolt holding the left front sway bar has been loose since I got my 83 FJ60. I thought nothing of it until I put a new bolt and bushings in and tightened it up. What a difference it made, like driving a new car. Problem is the new bolt and bushings from NAPA is 2 or 3 inches shorter than what was in there. it fit and there is no rubbing but now the left side is shorter (bolt measurement) than the right. Is this ok, or should I put another short bolt in the right side? I am having my oem springs rearched next week. Will they have to go back to the long bolts then anyway?
thanks
Mark
p.s. how do I loose my rookie status, I have several posts?
cahilc
Dry Fork, WV
Yes, IMO, both sides should be the same length. Wait until you get your springs to where you want them before buying new sway bar drop bolts ? Sway bar connects ? What's the correct name for these ? Once your springs are done then you'll be able to get the correct length.
Try these, spendy but woth the extra pennies plus good info on why for correct length.
http://www.4crawler.com/4x4/CheapTricks/SwayBar.shtml#DisconnectsV2
Cheers,
Cahil
