I've got a "chirping" sound coming from the front suspension of my '93 FZJ80 - I checked and re-packed the wheel bearings on a recent brake job so I've scratched that possibility. Any ideas - shocks? birfs? Anything else?
Sorry to be non-descript, I don't know how to describe it other than a high pitch rattle in the suspension (ie. driving slowly w/ the windows down). Suspension travel is fine over rough stuff - it just rattles on everyday terrain (pot holes etc...). I've been reading about the birf. repacks - it just seemed a lot more solid to me than whatever is making this noise when I had my hubs apart.
Eliminate the brakes by finding a stretch of road that does it at a certain speed, then gently apply the brakes and gently apply the throttle to maintain the speed over the same stretch. If it still does it, you'll have more info. If it's a more authoritative (seems heavier) type of rattle, then it might also be the spindle bushings, which develop slight slack but is not a concern for road use but might be with heavy offroad use and large tires.
If you can eliminate the brakes as the source, check your sway bar bushings ro see if they are shot (torn or worn). Mine chirped under the conditions you described and it was the from sway bar bushings. Cheap and easy fix.
I second the bushing theory. Mine has the same symptoms. I've read about "squeaky" bushings on OME's site and feel this is probably the cause --- Just haven't had time to check it out. I think it was on their main page? I'm anxious to hear what works.
Thanks for the tips - I'll check it out after work today, the sway bar is looking more like the culprit though (brake pads had all the pieces that came off). I'll let you guys know - T
btw - anyone know of a good place to buy bushings (individually)?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
