front speaker component set question (1 Viewer)
Houston, TX
I plan on installing some MB Quart component sets tomorrow and looking at the crossovers there is a low input/high input. I haven't taken the panel off yet, but is there one set of input wires for the tweeter and one set of input wires for the woofer? and if so are you putting them in the high/low inputs or just inputs in one? I had these in a suburban earlier and looks as if the pins inside the crossover were set to have only the low input and it ran the set.
Thanks
I can't remember exactly if there is a seperate wire for Woofer and tweeter, but I am thinking no, I think one wire, then the tweeter is protected by a little capacitor to filter out low freqs.
I think the input selections on the crossover is just to select if you are running seperate amplifer inputs to each speaker or "bi-wire". I think you want to just use one input and move the jumper to parallel the second input
