Beo,
Interesting stuff. I did an internet search and found some references to cementite on the Brembo website, and a bunch that came from various Yahoo discussion groups. No real scientific discussions of it as a side effect of overheating a brake rotor with use, but some references to it as a part of manufacturing them. I'm curious why a term "cementite" that's frequently mentioned by two companies who sell brakes (Brembo and Stoptech) isn't commonly discussed elsewhere.
The Brembo site was an impressive array of general braking information, I will say. The Stoptech article kinda stuck in my craw when he categorically stated he'd never seen a warped rotor. You know what I mean? I have not spent a lifetime in the brake industry but can absolutely state that my 80s brake rotors were warped. They were turned by a personal friend at his shop and I watched him measure the runout, then also watched as he lovingly adjusted the machine to take off just exactly what was needed to cause the rotors to run true without any lateral movement. This took extra care, where at a normal shop they'll just take a lot of material off quickly to move on rather than carefully adjust for each rotor's warpage.
Could the material surface variations be buildup, rather than warpage? No. The material variation began at the inner radius of the rotor's friction surface (where there is no pad contact), and continued radially outward across the pad's contact area. In addition, the movement of the entire edge of the rotor back and forth indicated the actual rotor's edge was moving - it was not getting thicker and thinner. This is not the first time I've personally seen this, so I detect a bit of BS.
I find the comments about breakin of pads extremely helpful and will never again put pads on without doing this. I suspect the Stoptech author is correct about hard spots developing from local hot spots, but kind of overstated his case a bit. No harm done, but I still believe in warped rotors.
Doug
