front pinion angle
Discussion in '40- & 55-Series Tech' started by TOYWNDR, Feb 8, 2004.
  1. TOYWNDR
    TOYWNDR
    16
    Oct 31, 2003
    I'm doing a spring over. During the cut and turn, any reason I can't turn the front axle to point the 3rd member flange 12 degrees up to point it at the transfer case; then turn the knuckle angle 6 degrees to fix the camber issue. I only use 4 wd at low speeds, I dont think vibration is an issue while crawling.
  2. TonkaC
    TonkaC
    339
    Jun 20, 2003
    Watertown, NY
    I haven't done it to mine yet so don't have personal exp but I believe that is the purpose of cut & turn and it is what I'll be doing to mine in a few weeks. Let us know how it goes.
    Chris
  3. pbgbottle
    pbgbottle Forum Lifer
    4,721
    Media:
    92
    Albums:
    5
    384
    Feb 8, 2004
    Cloverdale B.C. Canada
    thats what i did , . but i'm not sure how axle wrap effects that, if your runnin small block you might want to consider some axle wrap wittch way does the axle torque up or down also are you doing a shackle reversal , i think you are only suppose to turn the knuckle that much 6 degrees if you are .if not i think stock caster is recomended . something to do with the way the spring compresses during braking .?
    jake
