Front Passenger Window Replacement
Can anyone tell me if there are instances when the front passenger window falls off it's track and the window and motor needs complete replacement.Thank you for any info......
I just replaced mine. When it goes, it requires a window regulator. The window regulator is attached to the window via a tab (or tabs) that are designed to break away under load so the window doesn't shatter in the door. There are two ways to deal with it. Re-attach the window to the window regulator using epoxy or the like, or pony up money for a replacement window/window regulator module. I think it was about $250 but I can't remember. Here's another issue I found out the hard way. Once the module is replaced, there's a specific procedure to re-program the one-touch auto-up function. We put the door back together and didn't realize for a few days that we had a problem. When you hit the one-touch auto-up, the window gets to the top of the door, then backs down halfway, as if the pinch feature had been activated. I called the dealer and they told me they wouldn't relay the information to me over the phone or fax. I could come by and have them program it for $300, or I could copy the pages out of the shop manual and do it on my own. I'll tackle it over Christmas.
Scott
