Guys I'm starting this thread in hopes of narrowing down the source of a rattle/clunk I have in the Passenger/Right side of my 2011 Land Cruiser. Here are the symptoms followed by the variables such as upgrades or significant repairs. I'm open to testing ANYTHING, replacing anything and I'd love to hear EVERY suggestion.
Truck makes a clunk sound which can be heard inside when the passenger front wheel hits a bump. If the bumps are rapid like a broken road it happens on every cycle. It's most noticeable from 1-30 mph as the road noise masks the sound as you increase speed. It is not affected by acceleration or braking meaning the sound continues regardless of whether you're on the gas or brake. To me it sounds like a bad swaybar end link (but those are fairly new) or an upper ball joint (but those are new too). I do NOT feel it in the steering wheel. I've had the truck A LOT and three different mechanics have worked on it so maybe I/we simply forgot to tighten something that I'm overlooking.
VIDEO SHOWING CLUCK listen for the deep clunk over every bump.
History:
Retightened Every bolt/nut I could think of. March 2016
Checked and tightened body mounts (nothing was loose) March 2016
Removed Passenger caliper and disc to check for rocks March 2016
Greased front swaybar main bushings at the frame (verified correct torque)
SPC Greasable Upper Ball Joint replacements #25001 w/ AMS Oil Synthetic Polymeric Off-Road Grease
March 2016 (I thought the originals were the culprits)
OME/ARB BP51 Shocks, January 2016 (several other shocks over the last 5 years)
New Lower Control arms and ball joints and new related hardware Jan 2016
SPC UCA, January 2016
TRD 17" wheels 285-70-17 KO2 Fall 2015
Rebuilt Drivers side CV axle 2014 (Toyota)
KDSS Main Valve replaced 2014 It was rusted frozen (Toyota)
New Swaybar end links 2014 (when I first started noticing rattle)
Tundra Brake upgrade, New centric rotors and pads and OEM Tundra Calipers 2013 (installed by local mechanic)
Ideas:
tolerances between shock bolts and spacers in spherical bushings
Passenger CV warn (how do I test this?)
Something loose in KDSS joints (all bolts are torqued)
Something to do with the Tundra brakes (outer bearing had to be removed to install backing plate) Could an improper torque on the bearings cause a rattle?
Thanks everyone, I really appreciate the time it took to read to this point.
History:
Ideas:
