Front Driveline Slip Yoke Issues?
Idaho
I installed a 2.5" Dobisons lift and also moved my axle forward 1" in order to clear 35s on an HZJ73. Does the front driveline have enough travel in the slip yoke that I won't have issues off-road at full droop?
I have the truck fully drooped on jackstands and it appears to be okay but I would rather find out now as opposed to later.
Thanks
Based on the changes that you have made, it appears that you intend to wheel your Cruiser. Consequently, you should assume that your from drive shaft will require changes too. Taking to a good drive shaft shop local you appears to be advisable.
Good luck
