Hey Guys. So I reinstalled a third member in the front diff that had a new pinion, ring gear and kit installed. Pretty sure I fracked the axle seal on one side putting it together. Drove a few hundred miles then took it in for some tire work and found out the pinion seal was leaking profusely.
When I opened the fill nut I discovered moly grease n the gear oil so obviously I had damaged an axle seal but why would that cause a pinion seal to leak? Normally oil gets into the knuckle and that starts to leak. If I had put too much moly grease in the steering knuckle would this warm up and force gear oil through a pinion seal?
Anyone have experience with this?
