Front Crank Seal - HJ75 1985
Australia
Hey Guys,
I need to replace my Front Crank Seal on my cruiser.
What's the process of doing it? Can the engine stay in or have to be taken out?
Is it labour intensive?
the applicable engine manual will spell out the procedure. never done this but from what others have done the biggest challenge will be getting the nut off and installed with proper torque. that said, I think you might be able to do this on your 2H if you remove the fan shroud and fan and protect the radiator, but not sure if you end up having to use a puller of some sort, then you would not have enough room.
Okay thank you. :)
