Front Control Arms Install??????
Kansas City, Missouri
Before anyone slams on me I did some searching and couldn’t find anything on this topic. I finally got around to removing my front control arms to install the OME caster correction kit. I just got back from pressing in the new bushings into the arms and before I put them back in I had a quick question.
After reading Slee’s castor correction directions they say "to “remove” the front two bolts from the front of the arms first then remove the rear bolt. To "install" do in reverse order." Now for the stupid question does that mean I install the single rear bolt first then the two located on the axel? I would think it would be much easier to install the two bolts in the axel first then I have some leverage using the control arm to pivot the axel to get set the rear bolt in place.
If you are supposed to put the single rear bolt in first, what is the best way to rotate the axel to align it up with the arms?
Thanks
I've done this a few times too many and I have the best luck going from front to back. So the rear one is the last one. I use those racheting web straps to get the axle to move enough to line up the holes.
I got my front control arms on last night! Wow, this make a big difference in highway driving. I can see how there are several different ways you can put the arms back in. Here is how I did mine: Put the front axel bolt on first then pushed the arm up and placed bolt in rear frame. Did this on both sides, then used a ratchet strap to rotate axel back enough to get final axel bolts in. Very easy job! I can see were it would be a bear to get them in if you didn’t get the bushings in correctly!
Thanks for the help.
Congrats on the new caster.
For the record, I installed the front two bolts first, then the rear. To pivot the axle, I just put some manly muscle on the front wheels and pushed them back until my install partner could get the rear bolt through.
Hayes
I've been driving for over a year with a 2.5 ome and without CC bushings. I have the CC bushings just never put them in. With 35's on now the effect of incorrect caster is even more obvious plus I'm going to slap on the front J springs that have been sitting in my garage for months. Getting ready to finally press them in.
Searching around I haven't seen anything on the proper way to remove them other than to take out the front bolts first and the limited info in Christo's directions.
Is there anything else that needs to be done to remove them - ie should the truck be off the ground? Should I ratchet strap the axle before removing the bolts? Will anything happen if I just unbolt and drop them? I understand there's obviously going to be some axle movement but other than that...
The arms hold the axle in the correct position under the truck. You must support the weight of the truck with something else before unbolting the arms. Jackstands under the frame is the preferred method, and I prefer to support the entire vehicle, not just the front. It's a fairly simple job, as long as you don't drop the truck on your head- that tends to complicate it a bit.
-Spike
-Spike
Thanks
Howdy
I've done this a number of times and dont take the wheels off - let alone lift the the thing up! Leave it on the ground and it cant fall on you.
I usually fit the diff housing bolts first and use a jack under the steering arm or a pry bar under the spring mount to rotate the diff housing. Then push on a tyre to line up the hole at the chassis end - have a small pry bar handy here.
However you do it, I would do all 6 bolts up with the weight of the vehicle on the ground.
Take great care to press the new bushes in accurately! If you are going to do this regularly, make a jig to test that the bolt holes in the housing line up with the holes in your control arms before you try to fit it to the vehicle. I use a piece of plate with 2 bolts welded to it - if the bolts go thru the holes in the old bushes and the new bushes, all is good.
Just how I do it - hope this helps.
Matt
matt 105 said:
Howdy
Matt
Huh, so I guess either way works.
Any chance of overstraining a suspension component if the arms are removed without lifting the truck?
I would highly suggest supporting the vehicle. The control arms are what locate the axle under the truck. Without them bolted in place, the only thing holding your truck over the axle is the panhard bar and the driveline. If something shifts, bad things are going to happen.
-Spike
I hooked a come-a-long around the front axle then hooked it to the part of the frame that holds the spare tire. Did one side of the axle at a time. Would be helpfull to have someone to keep a eye on bolt holes to tell you to stop when they are lined up. I bolted the arms to the axle first.
