- Thread starter
- #21
The plot thickens
I have been going back and forth with different projects on the 40. Yesterday I spent some time trying to align the power steering pump. When I unbolded the cobbled together mount it fell apart in my hand. It looked like it had been broken for some time becuase the crack surface had a coating of rust and grease, the belt tension probably helped keep it together. I want to get a dorry style mount from Georg and be done with it. While I am in there I also want to do ford shock towers because the driver side is already hacked and welded together with sqaure tube.
Main question is if the box is mounted 'correctly'? All of the picture I have seen of frame plates and sleeves for a saginaw box show a different box mounted on the inside of the frame as opposed to the outside. I want to make sure im going down the right path before I weld a bunch of stuff onto my frame and then need to cut it off.
