front brake line hose skiiping backing plate
pbgbottle
Forum Lifer
Cloverdale B.C. Canada
front brake line hose skipping backing plate
does anybody know the approximate length of either of these hoses .
front axle outer hoses (skips backing plate) - NAPA 38881 (longer) or 38878 (shorter)
napa in canada does not have them in local wharehouse .on monday she will check other wharehouse . if she finds either one she is going to bring them in for me just wondering what the actual lenghts are . thanks
nuclearlemon
not an addict
Moderator
windy wyoming
don't know about prices in canada, but in colorado, it's only about $10 more for stainless custom lines. i got 4" over stock ss lines for about $20/ea
haystax
Diamond Valley, Nevada
I think the measurements are like 12" and 8" or something like that - I had stainless braided lines made and it was only like $10 more than the special order Raybestos hoses
Any hydraulic hose or hot rod shop should be able to hook you up with custom lines
Pighead
Stop calling it an FJ
Denverish
Banjo fittings for brakes?
I was thinkin' that too, but the speedshop guy persuaded me otherwise...
Anybody else using banjos?
greencruiser said:
I used the NAPA 38881 (longer) ones for my cruiser
I used banjo fittings fron clutch master cylinders on the calipers and it worked good
I also have the 4x4 labs hysteer :D
haystax
Mine use banjos, they are exactly what Downey sells, I just took the Downey pic and the old hoses and new calipers and they copied it exactly. I wish I had a swivel on the lines made up for the rears - kind of a pain to get the banjo fittings oriented right.
CruisinGA
Georgia Tech
Pighead said:
Oh. Never mind...
Yep. Not so sure I am a fan though.
One plus is that they do not round off so easily like flare fittings, somewhat more robust. But it is awfully easy to lose the copper crush washer, or install it dirty and thus have potential for a leak.
