It's not that it's a fancy kit. I noticed that when I changed my brake lines over to stainless there is a better feel to the pedal. Took out some of the sponge compared to original (and old) lines. The stainless are a little less prone to getting torn up on the trail as well.
Tony
Who makes a kit or sells the pieces to eliminate the front backing plates on a FJ62? Will need the metal spacer and would like a SS flexible brake line from the axle to the caliper.
Why do you want to do this?
Going to SS brake hoses I can see. I don't get eliminating the shields either. If you insist though I'm interested in the 62 shields.Why do you want to do this?
I get the brake line/hose part. I eliminated that short tube and the fitting on mine.
I've never had it happen or seen anyone get a rock stuck between the shield and the rotor. I'm not saying that it can't happen, just that I don't see any point in sacrificing on-road braking performance and rotor life for a 1/10th of 1% event.
