Can anyone give me a rough idea how much time I should expect to spend servicing the front axles, including:
- disassembly
- cleaning
- bearing replacement, including trunion bearings
- seal installation
- lube
- reassembly
I've done work like this before, but not many times. It looks to be a pretty straightforward job. I admit I'm paranoid about getting the hubs tightened appropriately at the end. The last thing I want is for it to work loose or to be too tight.
My expectation is that the maintenance is due, but there shouldn't be much damage if any. The mileage isn't high, and it was never taken off road as far as I can tell.
Also if there are any areas that could trip me up that aren't highlighted in the FAQ thread, I'd appreciate a heads up.
Thanks.
- disassembly
- cleaning
- seal installation
- lube
- reassembly
Thanks.
