Front Axle Rebuild Question: Circlip
Denver
I have the whole front axle back together, took a test spin and still cant figure out what this means: Can someone tell me or send me a photo:
WHAT IS THIS 8x1.25 Pitch bolt and Circlip:
After the drive flange is fitted and the cone washer nuts are torqued, the circlip can be fitted. Screw an 8 x 1.25 pitch bolt into the axle to pull it out and expose the circlip groove.
Install the drive plate (part cap goes into)
Quote:
Originally Posted by IdahoDoug
Go super easy on tightening the tiny nuts on the drive plate and cone washers. The torque is in INCH pounds, so easy to break right off.
Quote:
Originally Posted by sleeoffroad
when installing new drive plates (Most re-use old ones), paint them before installing them. They are not coated when new.
Coat the inside of the cap with MP grease and tap it on using a rubber hammer or a drift and hammer.
Re-install the brake caliper. Torque bolts to 90 lb-ft
during the re-installation of the caliper is a great time to replace the brake pads if required. 100 series pads last longer on the front
Re-install the tires. Make sure you torque the rims to the following specs depending on which rim you have:
Steel wheel and alloy wheel with conical seat lug nuts, 109 lb-ft.
Late alloy wheel with shank nuts, 76 lb-ft.
The bolt is threaded into the end of the stub axle, to give you something to pull the axle with. The stub axle needs to be pulled out so that a c-clip can be put on the end of it. Without pulling the axle out fully, the groove that the c-clip goes into is not visible nor accessible. The bolt is removed after the c-clip is installed.
-Spike
