Front Axle Rebuild - For FAQ (5 Viewers)
Soo, anyone know what these little guys are for (two gaskets)? They’re the only thing left from my rebuild kit and I have no clue where they go. I’m hoping they are for another year/trim/model?
That's the gasket for the outer cap section of an Aisin freewheel hub used on factory part-time 4wd 80 series (like mine).
There's another gasket (might be identical to the one used for the drive flanges on full-time 4wd 80's) for the body of the Aisin hub to mount to the actual wheel hub.
One trick (I'm sure everyone knows it!) is to make a pair of bearing race 'tools' using one of each size of race from an old bearing, cut a slot with hacksaw, carefully clean the cut area around the outside of the race, then you have two nifty tools to assist with seating new bearing races in the hubs. As the front and rear hubs on 80's used exactly the same two bearing sizes, they'll work for doing bearing replacement on both front and rear. Also, when setting the races, only ever use a brass punch not a steel one. Brass being soft metal won't damage steel surfaces.
Do you have a caliper? Measure. Maybe some light sanding on the new will give it the room it needs to fit snugly. 600 grit perhaps.
I dont haved a caliper. Should have brought them with me to work and took them to Napa or something. Thanks for your response. Just discussing it helps me regroup. 600 eh? I suppose if I sand the hell out of them I'll eventually get my room. Only need to do one. Noticed last night my new rear seal had its spring popped out while just hanging out on the parts table. Turned out to be a helluva job to complete. Tougher than I thought it would be but learned a lot. Heat is on big time where I'm at so that makes it even more fun. Thanks for your help MUD
I've a great digital cheap caliper that's invaluable during my rebuilds. Pretty close to this one on Amazon. Probably used it 100 times to measure things. Well worth the $20. Probably saved me $200 in avoiding incorrect purchases.
Hey Tom how is it going? Any luck?
hey man thanks for checking in. I really only have the weekends to go all out but I do have some small updates. Started sanding inner bearing. Decided to call cruiser outfitters and they gave me their ear. Before I went Thor I wanted to verify inner bearing diameter. They rock by the way. Buy everything you need from them. Anyway inside diameter of a bearing i took off and a new koyo both came to 49.6mm. No need to bother checking back with them, they are the right ones. So why are they so tight? Has to be spindles. Funny how easy the hub came off but new ones won't go on though. So I've yet to decide whether to Thor mg way into poundtown or just say eff it and order new spindles. Don't want to get the damn things on half way to only give up then trg to separate the hub from the spindle. If i do beat on it im thinking 3lb brass. Maybe a dead blow. Never used a db. Anyone know the spindle shaft diameter at the inner bearing?
.....figured if I take the hub studs off and can get a nice surface for max poundage. So that's what I'll probably do.
I gutted my remaining side last night to pressure wash the parts before the weekend. My inner bearing inner diameter is 1.969 inches. The spindle shaft outer dia is 1.967 inches, so just .002 clearance. I think you're likely within spec, just fighting slight misalignment
I think it's a M42x1.5 thread if I can convert to metric and measured correctly. Assuming 80ksi steel (likely higher grade but wanted to be safe) it would take 160ft lbs of torque to shear just 2 full threads of the nut. It's close to 4 threads if you look close but the outer and inner threads are partial.... and yes I was bored at work today. If the spindle threads look good, and it's a new nut, clean one last time, lube and get it all on with the 54mm socket. It shouldn't take anywhere close to the shear limit to get it all seated down. After backing off everything will be centered up and smooth as buttah! Keep us posted
I feel empowered. I am unstoppable. I shall be victorious! And maybe wheelin in the NF this weekend..... Thanks for your help!
Damn man put some sand paper on the bearing race. Or on the spindle, or both. You'll be surprised how a little room will allow that thing to seat in place.
I did and it worked! So both sides are on. Thought I ordered new lock nuts but can't find them. So a trip to Legacy in Tallahassee to get new ones and I should have it done. Thanks for your help!
Well looky here. Someone got his truck together. 2 small rest drives all seems good. No play or vibrations. Seem to hear a very faint click on the ds as the wheel revolves but might be from the birf swap. However it's going to go back up next week for an afternoon. The pos spindle I tried to limp through is going. So new spindle next week. When reassembling the lock nut it wouldn't go on. The original marred preload nut did go on but any of the new ones would not thread. It got cross threaded but was serviceable enough to throw the hub back on and drive it down the road just to see how the overall build went. Can't complain. Learned a lot and could do it in an afternoon now. Good yo see it off stands finally, even if for show lol. AND I can concentrate on cleaning the shop before next round. It's like a crap bomb went off in there.
All I can say is... Damn that's one sweet truck! I gotta white 80 (probably heat induced) fever coming on. Settle down with those pics!
lol thanks. After a year and a half baselining Id like to move on to the fun stuff. Might take the damage multiplier off. Theres a lightbar on the roof I might take off. Needs paint. Needs comms. That's all fun. Can't justify it without the complete baseline. Next up is 50' of vac hoses...all the little guys. Rear axle I guess. Steering box leaks like crazy. Minor oil leaks. But its a helluva platform. And it's come a long ways. Need to make a thread for it someday.
Potentially a stupid question...
Are there any differences in these parts for a US spec FJ80 VS a Japenese spec HDJ81. Are the parts all the same?!
Another option is to put the bearing races in the freezer and the hub out in the sun. I did this on my second side and with a few hits of the hammer on the bearing race driver it slid right in. Much easier than the first side when they were both the same temperature.
