Front axle differences
Central Cal.
I'm preparing for the mini truck disk brake swap for my 10/71. I have a 7/69 axle that I was thinking of doing the conversion on so I could still drive the cruiser and then swap out the axles when done.
I happened to be flipping thru an older SOR catalog and their "front disc brake change over kit" says its for 7/70-9/75. It uses all LC parts, no mini stuff.
What's different about the 69 axle from the 71?
I looked thru the FAQ's, tech and search to no avail.
Hi All:
Honestly, I thought all the 1969-75 FJ40 drum brake front axles were the same.
I would swap the wide-pattern knuckles onto your existing front axle housing. It is not that difficult to swap the later knuckles and brake parts onto a drum brake axle housing. Doing the swap on another axle housing will mean you have to un-do (and likely replace) the front u-bolts, and have to un-bolt the front drive shaft.
Good luck!
Alan
I know; I thought they were the same too.
My realistic time frame for a conversion could be up to 6 months, that's why I thought about doing it on the '69 axle and having it ready when I had the time to swap.
According to SOR, there might/must be something different about a '58-'7/70 axle.
only difference would be whether it is a ball and claw axle. I heard of a memer who had a ball and claw axles on a 69.
Mr Toyota using up old inventory??
I could see a ball and claw on a early '69 axle, but a July one?
I guess the first step would be tearing the '69 apart to see whats in there....
The dealership once told me Aug was the start of the "new model year":D
Making my July 74 a 74. Aug 74 would be considered a 75.
My July 69 was considered a 70. At least in the eyes if the DMV.
