Free Sub Tank. (1 Viewer)
Sydney ,Australia
Free sub tank out of my LX470, but you must organise your own freight or pick up.
I have now sold my LX after a very reliable 6 years, I will miss the quietness and smoothness of the LX .
Thanks to all that helped and advised over the last 6 years it has been a great wealth of information.
Sydney ,Australia
Still available, but i am no sure what you need to make it work , it comes with the sender unit, transfer pump and mounting straps.
rusty_tlc
Dain Bramaged Member
Reno, NV
Still available? So what else is needed to make it work on a US spec 100?
A $270 split filler neck* and either a custom circuit to make it work as a transfer system or extensive modifications to the OEM wiring to make it play with the ECU.
* I can get you the contact info you need to get one out of Japan.
SF Bay Area, CA
Sounds good. I may hit you up on that part once I know I can get the tank assembly first. Building a circuit for the transfer pump shouldn't be a problem... I'd rather keep it simple rather than rigging it up to work with the ECU.
Thanks!
OZ
If you waant it grab it, I was looking to get it for someone else.
Personally I would wire in a "OEM sub fuel" switch and use a change over relay to switch the pumps over, as well as the sender when the solenoids are engaged. But this is a bit more work and you need the solenoids as well.
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
