Just wanted to do a quick check before I get too involved with this project....are the FJ60 and BJ60 frames identical? Will I have any problems mounting a 3B engine or transmission on an FJ60 frame...engine mounts etc?
afischer
tell me your not going to swap out a good fj60 frame for another bj60 frame!?
Charles swapped his out because the old frame was compromised. The two engine mounts can be knocked off a 3b frame and welded in under 5 minutes to a prep'd FJ frame. You might be even able to buy the frame mounts new (I could for a 70 series) or certainly they can be fabricated in a couple hours from 3/16" x 4" stock.
if your frame is rotten please notice us.
if good, please follow other tips.
If you're serious PM me some contact info and we can search out a straight frame and have it prepped before you arrive. That's what I did. I found the frame in April or May and did the swap in December.
afischer
