iptman
A couple weeks ago I tested my lockers on a gravel lot and I couldn't get my front to lock up. The center and rear lock fine but the fronts don't. The indicator only flashes. They have locked up before so I know they worked at some point.
Last weekend we put the front end on jack stands and tried to lock up. No dice, not even a sound out of the motor. We pulled off the motor and were able to move the rack (through the hole on the 3rd) back and forth to engage/disengage the diff. Plugging the connectors back in the pinion did spin so we mounted it back up and sure enough (on jack stands) it would lock/unlock the diff. After buttoning everything back up we took her over to a gravel lot and the front locker would still not engage.
The only thing we weren't sure of is in the FSM it says to clock the pinion with the mark within 5 degrees of vertical. First of all is this clocked in the lock position or unlocked position. And second, why would this matter? The pinion only rotates a certain amount one way or the other so I can't noodle why you need to clock it before installing. Any ideas?
-Patrick
-Patrick
