Wanted ( FOUND ) Passenger and rear seats or the frames for 1962 FJ40 (1 Viewer)
La Crescenta, California
Hello.
Trying my luck and rolling the dice. Hope to hit a six.
Looking for passenger and rear seats or the Frame for the 1962 fj40.
Thank you.
Here is a set of rear, @Living in the Past can you verify that they are correct or not? Do 1962 have the shorter support arm on the front of the seats?
Here is a set of rear, @Living in the Past can you verify that they are correct or not? Do 1962 have the shorter support arm on the front of the seats?View attachment 2374822View attachment 2374823View attachment 2374825
The FJ25 had tall arm rest front and rear with two bolts at each mounting point. 61 still had arm rest but they were lower like the other FJ40 long jump seats. Still used two bolts at each point. 62 dropped the front arm and used two bolts but was down two bolts. Around 65 tabs were added to bolt to the top of the tub. Which this means these seats are correct for a 62.
Have to check on front passenger seat.
Could you post a picture of it? Just to double make sure..
I know the 1962 rear back seat plates is different then the 1965.
I do have the original driver seat and the rear grooves on the back seat plate are different then the grooves on the 1963 and up.
Thank you
Yeah. I figured as much. If there are any shared parts, I have some things left. Pm me and I'll look. Good luck!
