Forerunner Steelies On A FJ80
Thought I would add to constant confusion on back space, offset, center bore, hub centric and lug centric. Seems like there’s a different answer to all these on Mud. But I have a 95 that’s hub centric. And I just snagged a set of these 17x7 off a Forerunner for $150😁
And they fit absolutely perfect and center up against the hub with the the little tabs quite nicely. I just got my BFGs mounted up and still waiting on my lug nuts. But found out the stock mag lugs do have a 60 degree bevel on the very edge. Kinda makes sense because they don’t give an extra set of nuts for the steel spares. I assume I could probably run them. But going to wait to be sure.
They do sit inboard just a smidge. As you can see below n the pics. Perfect for flareless which I am thinking of doing. If not I will be buying some spacers.
The tires are 285/70/17 and are just a 1/4” or so more than 33 inches.
