The idle is dead steady. Everything moves freely with the throttle cable and plate. When I installed the supercharger (about a year and a half ago) I also serviced the throttle body. I'm not sure what the timing is, but the last time I checked it, it was within specs. The hesitation is like it gulps too much air and goes full lean...as if the MAF and TPS input arn't telling the ECU to ramp the injector pulse up fast enough. As far as I've been able to tell the Ford MAF has the same analog voltage output span as the rehostat of a door type.
I'm going to check my timing again just to make sure it's in the right spot.
Cruiserdan, I have an old Edlebrock water injetion system that I was thinking of using, what are you using?
Does it work well?
How about fuel octane requirements with the injection?
