Yeah they did the alignment on it already. I mean, sucks but oh well. Y'all think raising the front an inch would screw it up that bad? I'm a suspension noob, so I honestly have no idea if it would be minor or catastrophic.
IMO an inch is significant enough to warrant another alignment. Keep in mind, once the TBs are adjusted they will need to settle. So drive a bit (say a couple days) before getting alignment. Recheck height and see where you are at, adjust again if necessary. Also, keep in mind, you want to adjust TBs to final position (height) while tightening 30mm bolt vice loosening. So if you over adjust, loosen 30mm bolt more than necessary, then tighten to final position. Lastly, the best way to keep track of adjustments is to mark the bolt before you start so you have a reference point. One full rotation of the bolt should be around 1/4" increase/decrease in height. This also depends on the TBs, mine are aftermarket, so this may be different for stock bars.
