+1I have a Gamiviti rack and it was recommended to use DAP Dynaflex Ultra...no leaks and super easy to use!
Might be late too late on this one but I would not recommend that. Locitite is literally the root cause of any/all "nuts fell into the roof" stories that you hear about. Specifically one bolt gets removed, then the other gets twisted, and the path of least resistance is the whole nut carrier thing popping free and spinning, rather than the bolt coming loose. the way to avoid the issue is alternate between the 2 bolts on each tower, back them out evenly then it's never been an issue. But your new bolts will be under load from a rubber sealing washer, surrounded by some type of sealant, they really shouldn't magically back out somehow.I’m planning on using Loctite blue threadlocker for the bolts to prevent backing out.
Thanks all for the suggestions.
Thanks for your advice, especially the video you posted on YouTube regarding removing the bolts. I did end up using the blue locktite on the new screws, and I guess this is down to paranoia from when I used to race bikes. Obviously track conditions are more demanding than the street but considering the process you outlined in the video worked so well I was ok with re-applying the threadlocker.Might be late too late on this one but I would not recommend that. Locitite is literally the root cause of any/all "nuts fell into the roof" stories that you hear about. Specifically one bolt gets removed, then the other gets twisted, and the path of least resistance is the whole nut carrier thing popping free and spinning, rather than the bolt coming loose. the way to avoid the issue is alternate between the 2 bolts on each tower, back them out evenly then it's never been an issue. But your new bolts will be under load from a rubber sealing washer, surrounded by some type of sealant, they really shouldn't magically back out somehow.
I just removed my OEM rack last weekend. Your video was very helpful. My OEM bolts were super tight and took a lot of torque to break loose and more than it seemed they should unscrewing them all of the way out. I alternated between the two until I got them removed. There was a large amount of blue Loctite on each OEM bolt (I assume from factory). The only issue I can see using Loctite is if you were to totally remove on bolt the break the other loose. Is this what you are talking about when you recommend not using Loctite?Might be late too late on this one but I would not recommend that. Locitite is literally the root cause of any/all "nuts fell into the roof" stories that you hear about. Specifically one bolt gets removed, then the other gets twisted, and the path of least resistance is the whole nut carrier thing popping free and spinning, rather than the bolt coming loose. the way to avoid the issue is alternate between the 2 bolts on each tower, back them out evenly then it's never been an issue. But your new bolts will be under load from a rubber sealing washer, surrounded by some type of sealant, they really shouldn't magically back out somehow.
exactly.The only issue I can see using Loctite is if you were to totally remove on bolt the break the other loose. Is this what you are talking about when you recommend not using Loctite?
On your website, you recommended PL Loctite Polyurethane Roof & Flashing Sealant. Do you still suggest that product? Or should I stay away from loctite to reinstall factory roof rack?exactly.
I have switched to Dynaflex, which is a little more readily available than the product made by Loctite. But both products are very similar in being a non-hardening polyurethane, window and door type sealant.On your website, you recommended PL Loctite Polyurethane Roof & Flashing Sealant. Do you still suggest that product? Or should I stay away from loctite to reinstall factory roof rack?
Sweet! That's exactly what I needed to know.I have switched to Dynaflex, which is a little more readily available than the product made by Loctite. But both products are very similar in being a non-hardening polyurethane, window and door type sealant.
don't confuse that with the thread locking Loctite, which is what is being discussed here. totally different product. I don't use the thread locking stuff, just the window and door stuff. There's confusion created when folks call thread locker "Loctite" as if that's the only product they make...
same hereI have a Gamiviti rack and it was recommended to use DAP Dynaflex Ultra...no leaks and super easy to use!
