I recently finished a front axle rebuild on my 1985 FJ60.
Not all wheel bearing seals are created equal and if anyone has done or is thinking about doing a front axle rebuild , its something that ( assuming you don't brake a birf ) you will likely only need to do once.
I wont go into the details of the kit I bought or the vendor who sold it as " best quality " but I will say that one part that should be purchased separately from Toyota is without question the wheel bearing oil seals.
I examined three types of seals , the local auto parts store seal - green , the " high quality " aftermarket seal - red , and the OEM Toyota seal - metal. Without question the Toyota seal was heavier, had more steel and was far easier to press into the hub without damaging it
Both the red aftermarket seal and the Toyota seal were approximately the same thickness
They cost about 19$ each and can be ordered from any dealership. The Toyota Part number is 90311- 62001
Photo Descriptions : The green seal is the local auto parts seal, the red seal is the seal that came in the kit and the steel silver seal is the factory Toyota seal - you be the judge
