## Let me start by saying I have limited( OK, if any ) mechanical & electrical skills beyond basic, am a first time Toyota owner and am on a beach 45 miles from my factory trained indie mechanic or the local dealer.
Started with the previous owner retaining and pulling his gucci Baja Designs LED light bar upon my purchase, leaving a Black/White/Green set of wires connected throught a relay to OEM fog light dial on turn signal mast.
My replacement LED bar had only Black & Red wire leads. I connected:
Black<=>Black
Red<=>White wires
Light bar worked fine via low beams. Engine turned over and started as usual, but light bar turned off when high beams engaged via turn signal mast.
Then i overthought the situation and hosed myself by connecting:
Black<=>Black
Red<=>GREEN
NO lights and now engine won't turn over to start, just a ticking/clicking sound.
Could solution it be as simple as clearing error code(s) and/or checking fuses?
Any suggestions on how to proceed?
Thanks for any help.
Black<=>Black
Red<=>White wires
Black<=>Black
Red<=>GREEN
